juddspaintballs
my balls are painted!
Stopped by the local speed/diesel shop and ordered a BUNCH of AN fittings. This is not going to be cheap by any means, but it should be bulletproof and done better than GM ever did it. From what I can remember ordering, I have a 8AN and 6AN bulkhead fitting coming in, fittings for those to convert to hard pipe for the pickup tube and return tube, fittings to go to rubber hose to go from tank to frame rail, then fittings to go back to hard line, rolls of aluminum 1/2" and 3/8" lines, and a fitting to go from 1/2" hard line to 3/8" pipe (although now that I think of it I should get it from 1/2" hard to 1/2" pipe) for going into the pre-filter kit. I will probably leave the plumbing I have in place from the filter to the lift pump. From there, I still need to figure out what parts to go from the lift pump up to the FFM and then figure out the return line too (in 3/8"). It'll be some work to get this all done, but I hope to never have another fuel issue again with plumbing like this.
Sadly, I could probably have bought the raptor kit from Leroy and it's lines for less than this is going to wind up costing me...
