Acesneights1
WOW...
opcorn:
This represents a Pulse Rate\Repetition Modulated digital signal, beginning at 0v, rising to 5v, falling to 0v - no analog about it, but definite frequency content:
5v_____
0v_____ ________(a)|____________(b)|_________
What is the effective voltage from (a) to (b)? This is frequency dependent - at 1hz the on-time is minute compared to the off-time - so put a DVM on this signal to read 0v, like a dead circuit, even tho there is a viable signal - at 1million pulses\sec, DVM could read some voltage above 0v, but not 5v, depending on the DVM - "Whups, this module is dead, Vern - toss me a nuther'n off'n the floor, over there!"
5v_____
0v_____ ________(a)|||||||_______(b)|||||||____
What is the effective voltage from (a) to (b)? Same here, but since the on-time has increased, DVM could read some value greater than 0 but less than 2.5v - "Whups, low voltage, Vern - time to change the battery(s) on this rig"
5v_____
0v_____ ________(a)|||||||||||||||(b)||||||||||||
What is the effective voltage from (a) to (b)? Same here, but since the off-time (spaces between the pulses) is still greater than the on-time (pulses), DVM could read some value around 2.5v - "Hit me with a nuther one uv them modules, Vern!"
This represents a 0 to 5v Pulse Width Modulated digital signal - no analog about it
5v_____ ''''''''''''''''''''''''''__ ''''''''''''''''''''''''''''''''' __ '''''''''''''''''''''
0v_____ _______(a)| |___________(b)| |________
*What is the effective voltage from (a) to (b)? The on-time has increased, compared to the pulses above^, so the DVM will flicker to some value above 0v but less than 1v
5v_____ ''''''''''''''''''''''''''____________ '''''''' __________
0v_____ _______(a)|..................|(b)|
**What is the efffective voltage from (a) to (b) ? Here the on-time is greater than 90% so at 1hz DVM will read 5v but with a repeating flicker to some value between 0v and 5v, again depending on sample time of DVM - increasing the frequency will stop the flicker
This represents a 0 to 5v digital Square Wave signal, no analog about it:
5v_____''''''____'''''''''''''____'''''''''''''____
0v_______|.....|____|.....|____|.....|_____
What is the effective voltage of this signal? Again with the frequency, at 1hz DVM could read 5v-0v-5v-0v, depending on the sample time of the DVM - at 1mhz DVM would read somewhere between 4 to 5v - if your DVM would read voltage at frequencies that hi
5v_____ ''''_'''''''_''''''_''''''_''''''_'''''''_''''''_'''''''_''''''_
0v_____ _| |_| |_| |_| |_| |_| |_| |_| |_| |
What is the effective voltage of this signal? Here, at 1hz, DVM could flicker about 2-4v - at 1mhz DVM would read somewhere between 4 to 5v
Remember, in digital signals, the signal is driven to the upper rail, in this case 5v, but is also driven to the lower rail, 0v, so DVM must integrate and average the upper voltage with 0v - you will get different readings in DCV and ACV ranges
An oscilloscope is the desirable tool for investigating computer-controlled systems, as most everything is digital: solenoids, valves, switches, position sensors, etc - temperature and pressure sensors are mostly analog, with variable resistances and variable voltages representing response to change - these can be read with a 'scope or DVM
With inductors the system, inductive kick may be a viable part of the signal, but not even seen by a DVM - inductive kick can be as high as 2400v in a 12v system - the FS coil gives between 100-180v of inductive kick when power is applied, which is why the PNP driver transistors are hi-voltage rated, in addition to hi-current rated, designed to pass a lot of current thru the FS coil
The waveform at question * resembles the Fuel Injection Pulse Width at idle, and at question ** resembles the waveform at FWOT, but on a much higher voltage, as the drive voltage is just under +12v battery voltage, due to solid state forward voltage drop of the bipolar drivers and the steering diode in the emitter circuits - on-time to off-time is determined by demand fuelrate - the max pulse width is never as wide as the duration for the rollers to ride comletely up the ramps
(The apparent waveform misteaks are not correctable)
You lost me long agoIn elctronics, Discrete is transistors'n'diodes'n'capacitors'n'resistors'n'transformers'n'fuses'n'stuff - can have discrete digital and discrete analog circuitry
Integrated Circuit is some of that discrete stuff scrunched together on a teeny silicon circuit board, usually in an *injection-molded epoxy package - can have IC digital and IC analog circuitry
Transistor-Transistor-Logic is mostly direct-coupled bipolar transistors with a few-odd diodes thrown in as token representation
Bipolar transistors are NPN or PNP doped junctions, usually silicon but sometimes germanium flavored, are lo-impedance current devices, transfer function results in odd harmonics, single polarity drivers either pull up to the rail, or pull down to 0
Field Effect Transistors are N or P doped, are hi-impedance voltage devices, operate similar to electron tubes, transfer function results in even harmonics
Complementary Metal Oxide Silicon transistors are hi-impedance FET devices, direct-coupled circuitry is similar to Complementary Output Pair hi-fi power amps, where N device pulls signal up, P device pulls signal down (and vice versa), very sensitive to static discharge
Digital is on or off
Digital circuit control is on or off
Digital logic is multiple on\off circuits parallel-arranged in bits'n'bytes
* Tho't I'd throw that in to maintain the injection-oriented theme of this thread..............
Because the rollers ride up the ramps quicker as rpm increases, with resultant quicker pressure rise - the rollers do not need to make the entire transition from the valley to the ramp peak to generate pop pressure - residual pressure in the pipes mean the pressure does not have to build from 0 - housing pressure @25psi at idle rises above 125psi as rpm increases, so pressure is greater than 0 when rollers are in the valleys at the start of the ramp
The signal from the PMD to the FS is not digital.
Change in frequency would not show a change in amplitude on a DVM, thats just nonsense. Voltage is determined by the peak to peak amplitude, has nothing to do with frequency. It could be 60Hz like commercial power 120V, or that same 120V could come out at 400Hz or whatever.
OK but what that thread was about was Tony kept referring to the injectors as nozzles which was getting me confused. The GM 6.5 Manual also refers to what we tend to call injectors, nozzles . Tony was trying to explain to me that what I have a nozzles not "injectors". That is why I was getting confused. When Someone says nozzle I think like the end of a powerwasher and that would not make sense. The engine being discussed in that thread was a 3208T cat but same thing really applies to 6.5 ?? Or am I just more conused ??
The other issue was I could not get the truck to strat even after priming i but that was because I was not priming it properly. How we finally got that truck started was dragging it down the road in gear to spin the motor faster than the starter could because as I have said before I really really don't like ether even though in the case of a low compression 3208T it's almost a nessecity..
The "tuning" of the IP..................
And, tnx for that link, turbovanman
also allows unscrupulous businesses and giant operating system software conglomerates to remotely awaken your PC in the wee hours of the morn while you yet slumber, perhaps in alcoholic stupor, for an unauthorized, unbridled session of ransacking your files for passwords, i.d. numbers, account numbers, phone numbers, contacts, etc, anything usable\salable on the www - be afraid.....be very afraid................
