buddy
Active Member
the injectors set injection pressure in it's entirety, no if's, and's, or but's about it
- the system will have 1850psi press if the injector springs are calibrated to 1850psi
- the system will have 2275psi press if the injector springs are calibrated to 2275psi
- the system will have 2700psi press if the injector springs are calibrated to 2700psi
So I asked the Stanadyne Engineering department about this, because this pop pressure is the line pressure goes against my understandings. The man said the line pressure will vary based on fuel volume flow. So at idle it may only just have a line pressure just above injector pop pressure, but at higher volume demand it will increase the pressure to the higher limits of the pump.
How do you increase flow out of a fixed orifice in a shorter period of time (higher RPM)? You increase the pressure.
Perhaps he didnt know what he was talking about either, but I wouldnt want to have people thinking marine injectors or 2700psi pop pressure will kill their IPs if it isnt that big of deal.
I couldnt get any documentation from them, everything is "proprietary".
One thing I would really like to know about marine injectors, is if the flow rating actually increases. Is the nozzle larger? Is there a flow rating for the stock injectors lb/hr or CC/min type, and is there any different rating with the high ouput injectors.
The pump may only put in so much volume per injection event, but with what I have read some amount left over gets recycled in the pump, and perhaps you could just have less recycled fuel if you get a larger nozzle.
Any injector builders out there?
