MrMarty51
Be a shame to discard these nice Bosch Nozzles and Pintles if the could be made to function once again.
Now it I can get this one to do a single pop.
For pressure to slip by so it lifts ? I think thats how they work but all the injectors I had tested, mainly pencil type, never leaked more than a drip over an allotted amount of time.the ones I've seen have a groove in the pintle, maybe get out a magnifying glass
It will be interesting to see what that diesel shop comes with results on the new set of Bosch units I sent over to Him.Maybe I should clarify that, the ones I see peeing have a groove in them from wear/erosion
Maybe it is going to require some more polishing on the pintle and the pintle seat within the nozzle. It could be that the groove wore through is partially honed out but still enough of it left for the fuel to get enough volume between the pintle and the seat and lift the pintle to make it leak by but not to slam shut to pop.sounds like your on the right path. Your giving me inspiration for when I get around to try my hand at this with the ones I have.
@Rockabillyrat might be able to give some tips and tricks on these units as what to look for and the to do's when it's holding but not chattering.
Yup, very very rapid pump.How fast are you pumping the tester? I do it pretty fast to get them to chatter. If you go too slow they will open and just stream out. You need to simulate a pump by building a lot of pressure fast. Keep in mind that the pop tester volume is 100s of times more fuel than a single injection event when its on the engine. A pump flowing 100cc/1000 is only putting putting out .1cc every spray.
I had tried it years ago when I had tennis elbow. Sheaf cartilage runs in, like a tube, wore through. Cant say it really helped but seems it didnt hurt too. I do remember that taste.Yup! Only go slow when check for the droplet. Otherwise act like you are jacking up a rig to change the tire, and last one home gets no desert!
On that DMSO- USE EXTREME CAUTION!! If you smoke cigarettes- dont even mess with it!!
Anyone thats ever got it on their skin knows its crazy stuff. I used to have to tend the horses that were injured or old and run that stuff on their hurt joints.
Every now and then get it on me, like on my forearm and within a minute or so it tastes like you drank carburetor cleaner. That stuff soaks into your bloodstream and carries throughout your body is the way I understand it.
There are some chemicals, nicotine being the most common one, that it can carry into your system. Back in the late 80’s I had to go get some and take to Grandma about 100 miles away, arthritis was tearing her up and I guess that helped her. This was before FDA approved it on people. The people version is super watered down dmso, And I understand why. A decade later one of my uncles had to go into the hospital and nearly died because he was using dmso but was smoking a couple packs a day. Well handling the cigarettes he would touch some of the tobacco and had the dmso on his skin. It fast tracked the nicotine to him and had a heart attack.
The blood tests got reran 3 times before they realized what was happening. The nicotine content in his system was through the roof. Dr said he would have had to smoke 3 cartons a day for months to get that much nicotine in him. Once he found out about the dmso he demanded the entire family that was around him to come in. He had a cop there and explained anyone bringing him pure dmso again would be charged with his murder.
So- whenever you use it- wash away all the oil products you can first with brake cleaner or similar. Let it dry and go wash and rinse very well first. Put on the nitrile or rubber gloves. Just rinse with clean water if you get it on your skin- but out of curiosity if you want to see of that taste thing is real- don’t get carried away with it or use as a prank.
You don’t know what chemicals someone may have on their skin.
For those that enjoy filling out paperwork on freedom of information act- look into previous uses by some gubmint agencies with its use. Hint- splashing someone is not as trackable as cordless hole punchers sometimes. Nuff-said.
Yes, I always have some on hand. But i keep it like any severe medication- no where near where any kids, even teens, can get to it.
I went for years without any kind of hand protection. About the last fifteen years of working for the DOT that I became aware of the damage being done to my body. Not just the hands but everything that the solvents affect when they soak through the hyde.Its no joke- sometimes when instructions say wear gloves, they mean wera gloves.
Not yet.Yup. Grandma used to out on the pure stuff. She would use the roll on bottle like you use on a horse. Except she would start to roll it on a paper towel or paper napkin that would be discarded, then just touch the ball to the sore joints and not roll it, and never rub it in.
Too much is an eye opener for sure. Nice description there Denata,
Any word from the shop with your injectors?
