Updated?........Design and/or filtering properties?.......Microns changed?
Seems all the old (metal) ones were made by Standyne, Just packaged in different boxes......That said, with the new (plastic) design, if they're made by different manufactures, quality control can go skechy.....
Not to mention that all the filters have gone up around $10.00 in the last year, What's up with that?
I just switched to the Baldwin filter with the plastic cap. I don't know the micron ratings, Heath recommends the Baldwin so I decided to try it. My veg flows through the stock filter and I was having trouble with flow restriction on the standard type of filter, the Baldwin clearly flows better as I'm no longer having problems. There are quite a few more pleats on the Baldwin so it has more surface area to flow through, though again I'd like to know if the micron rating is the same.
Well now that's interesting, just spec'ed out the 33376 and 33976 on the wix website. The new 33976 has a plastic top like the Baldwin unit but here is the surprise the micron rating went down:
33376 - 5 micron
33976 - 14 micron
Wix just lost brownie points for me there looks like I'll be getting around to installing a racor finally. Could not find a micron for the Baldwin BF1201
Cheers
Nobby
Nominal means the filter is 50% efficient at pulling whatever the micron is Absolute means the filter is 98.75% efficient at pulling whatever the micron is.
Hope this helps.
-----Original Message-----
Sent: Thursday, September 24, 2009 12:38 PM
Subject: RE: Filter Rating
Hello,
Thank you for the reply! I understand that the 9 micron absolute means that something larger than 9 can't physically pass through, but what does the 3 nominal mean?
David
Sent: Friday, September 18, 2009 9:26 AM
Subject: FW: Filter Rating
David,
The BF1201 has a 3 nominal with a 9 absolute micron rating.
Thank you,
Sent: Thursday, September 17, 2009 10:17 PM
To: Info
Subject: Filter Rating
Hello!
Could you tell me the micron rating of a BF-1201 fuel filter for a GMC 6.5 diesel? I've been using one with good success, based on fuel pressure readings it flows fuel more easily than the other brands I've tried, but I wanted to know the level of filtration its rated for. Thanks for any help with this.
David
I emailed Baldwin and got the specs on the fuel filter, here's the text from the emails:
I'm fine with those specs. I realize many people feel 5 micron is the desired level, but to me this comes close enough and the flow is much improved over the filters I was using previously.
I sure would recommend you replumb your system with a separate veggie filter. Heated filter from Frybrid, or VegPower would really be great. You are running the risk of not purging completely the veggie from the filter manager, which can cause some significant trouble down the road.
JMHO
Also, Another question about fuel filters. When they start to become clogged up, or full, do they start to filter BETTER due to the fact that even clean fuel starts to have trouble passing?
