ak diesel driver
6.5 driver
you notice I said I'dheard of guys doing that not that I'd done that
care to elaborate?
Yup, you may also notice I didn't say you did it.
Now you know that I know that you know that.....:hihi:
I'm about to test a tune that's reported to get 20-25 mpg on a 6.5 with 4:10 gears.
It will necessitate a few changes to the truck as it sits.
Time will tell the tale......
I'm about to test a tune that's reported to get 20-25 mpg on a 6.5 with 4:10 gears. . . . . Please don't ask.
Tease . . . !
Am still months, to a year, away from upgrading the Burb (unless something fails first), so let me know if there is interest in a nearly stock test bed / control group running 3.73’s.
I've heard of guys decarboning an engine by getting it good and warm and running a garden hose down the intake. as much water as it will take without stalling it along with a lil throttle
In general the tuning lowered shift points, increased shift pressure, and the one good thing was upping boost where needed, but leaving it next to nothing when you dont need it. compared to arbitrarily setting the boost curve high like others do. I cannot tell if the terribly low shifted timing curve was for 5068 IP, or they do it for all of them, I didnt dare get another one from them to find out. The low timing might be useable with low gearing.
I'm not familiar at all with the 6.5 PCM's and tuning, but I was wondering if they were hindered with Torque Management?
I know that it saves a stock tranny from bad drivers and bad/non-existant maintenance, but a well tuned, well maintained stock 4L80E or a built trans could benefit from removing it from the tuning. This is for the Vortec truck engines (96-current), which is the only engine I have any knowledge about, when it comes to tuning.
Rolling down a long hill in neutral with the motor off and stiff tail wind?care to elaborate?
Depends on what you call "hindered"...
Does the cal protect the transmission?
Yes.
Does it hurt performance?
That's a matter of opinion and what you consider "performance".....
Radical version of the "Georgia overdrive"Rolling down a long hill in neutral with the motor off and stiff tail wind?
The old Water de-carbon thing is Very not advisable in diesels. Unless the spray in cleaner clearly states its for diesels don't use that either. Don't use ether eitherIve done this on gassers. Water will decarbon quickly. Have you noticed if you have a head thats been pulled and you just let it sit the humitiy alone will cause the carbon to flake off.
I think GM even has their "GM top end cleaner" that uses the same method.
I've done it on gassers to. Tractors (gas) seem to carbon up more than road engines, so that's where I picked it up, from some old geezer. Now I am a old geezerI did it on a gasser.
