great white
Well, there goes another 10 bucks Canadian....
LOL!
Thank you!
I can do it with a T for the pressure guage, but suggest you place the pressure sender at the drain side anyway. Keeps it tucked out of sight.
It is logical to put it on the IP side, as then you can monitor filter health, because it will be post filter, if pressure drops over time might need filter change, and in general its like 20% lower pressure on the IP side.
In the picture you dont show the upper IP fitting, but I assume its in the kit.
I'm a proponent of monitoring @ outlet of the filter mgr or just prior to IP inlet also; as that will give indication of what IP is getting, also advance warning something is amiss with the fuel supply in general, be it filter/s if equipped with pre filter, lift pump, or tank sock
