ak diesel driver
6.5 driver
from everything I've read/ experienced it's not so much about keeping it cool as minimizing the thermal shock or expansion and contraction cycles. I had one fail only in subzero weather, when it warmed up it was fine
New 6.5 owner here. Just traded a 92 Cherokee Limited (plus $2400 cash) for a very nice, original 95 Suburban LT. I have an idea I wanted to propose here and see what all the experts thought of it.
I have a peltier cooler from one of those little 12v beverage chillers laying around in my shed. It has a fan on the warm side, and what I'm thinking of doing is taking off the cool side heatsink and sandwiching the peltier element between the aluminum plate side of the PMD and the fan-cooled hot side heat sink. Then I could remote mount the resulting PMD/cooler "package" in the cab connected to a switched 12v source.
With the peltier cooler and fan it wouldn't need air circulation from the AC system - it will make ts own cooling. No need to weatherproof the PMD. Seems simple and reliable enough.
Any thoughts?
I like the idea of putting it in the cab where it is in a relatively climate-contolled environment and will stay nice and dry. However I want to make sure it gets enough air flow, so I think I'll go ahead with using the heatsink AND fan to ensure some steady air circulation.
It's been tried by a few here, myself included. There is a reason everyone keeps saying inside the front bumper...
That is the reason i mounted mine in the engine air intake flow path in the pass side fender,..The FSD is allways dry and easy to change out if need be.Yeah, and having read this whole thread in one sitting I concluded that reason is air flow. That's why I plan on using a heatsink with a fan - to give it that constant airlow.Earlier posts also indicate that minimizing the range of the temperature cycling is almost as beneficial as keeping it cool. There's no question that inside of the cab is a much more temperature controlled environment than behind the bumper.
The other issue is the one of weatherproofing. Water promotes corrosion - another significant cause behind one of the primary failure modes. This may not be a big concern in the deserrt, but it is definitely a significant concern here in the great north WET. It seems to me that locating it behind the bumper would not only expose it to more water induced corrosion, but would also put it at risk for a BIG thermal shock - if a hot PMD got hit with a big splash if cold rain.
Actualy it stays a more consistant ambeint (sp?) temp behind the bumper. Inside the cab can reach 140 + degrees on summer days then drop to 40-80 degrees with a/c on while the same truck with a bumper mount is only "room temp". There may be exceptions like living where its -40 like Les & Bison, but for most app's bumper mount works great and no need to run a fan.
As far as weather/water go's the PMDs are waterproof the one exception being the pins on the connector. They have a nice seal, but its recomended to squeeze a blob of dielectric greese in there to waterproof them. Also always point the female connector body of the PMD down so water cannot stay in there.
I've sold a couple thousand PMDs and its a very rare problem (cant think of any) that will have corroded pins.
To be clear Im not arguing with you just stating my observations on the many units I've sold.
I was of the impression that the aluminum back plate of the PMD doesn't come sealed to the plastic body of the unit. Did I get some bad info somewhere?
That's the waterproofing I was talking about. I hate the idea of gluing it to the heatsink and the possibility of it not being water-tight...The componeints inside are potted in a epoxy type compound to waterproof them. The transistors are exposed though, I recomend after mounting to heat sink to run a bead of Goop sealant around the base to seal PMD to the heat sink.
