buddy
Active Member
Is it a GLE or GL4 program from Heath? do you have a functional EGR? I would call them to see if they ever set them that low, as I suspect they set all of them closer to 11 degrees. If that is the case I would spin your CPS in the timing cover. Try unplugging the CPS and see if the desired/measured timing changes or if the miss and cam references stop incementing.
Your idle fuel rate is fine. The file I posted gives some guidance on taking the OS out and how to set it back up in the truck. I would first find out if the program is supposed to be 5.7 degrees.
