WildWilly
I have a 93 6.5 TD that needed the flywheel replaced. I just installed it and diagnosed it's failure due to the gears not sinking in deep enough from the starter to the flywheel. Shimming the starter only pulls it further from the flywheel. Any ideas, maybe I need to trim the top of the starter housing?
Secondly, the truck starts within 3 to 5 seconds the very first time I start it for the day, after it is warm it refuses to start. <-- that's another reason the flywheel went as well but not THE MAIN reason. My fuel filter is new, OPS is good, electric pump is running & pumping fuel and the truck runs great when it's running. I haven't ran a compression test yet but it isn't smoking while cranking it when it doesn't want to start while warm. It seems like a fuel problem to me, therefore I haven't checked compression. I'm sure someone has ran into this before, does it sound like the injectors may not be popping or maybe the IP plate warped? Any ideas what to do next?
Next problem is the shaft on the wastegate is worn out & I don't like the spring load that is supposed to work the gate. What are you all doing to improve the WG? Can I repair the wear in the shaft or does it need replaced? I have another complete 6.5 from a non turbo truck, a 95 P30 that has the same IP and TPS so swapping parts isn't going to cost me alot of cash but I don't want to spend countless hours playing guess your best. I've searched quite a bit & found similiar problems but the starting problems I found were for newer IP's with a PMD being the culprit, that's just not my case. I know there are several folks here that are pretty darn slick when it comes to the 6.5 and it's always nice to have a few brains working together.
