legendman
Hi all need some help with my 6.5 dooley
Here is the filled out checklist
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). _Stalls and hesitation when pushing on accel pedal____________________
- Year: __1996____
- Truck model and class (ie: c2500) _K3500________
- Automatic or Standard ___Auto_______
- Mileage: (indicate miles or km) __244k_______
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ___PMD________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? ___Turbo___________
- Ambient outside temp: (indicate *C or *F) __40-50 degress________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ___# Diesel______
- What fuel additives are you using? _Diesel Kleen__________
- Where are you located? __Connecticut___________
- Air filter __Replaced_______
- Fuel filter _No idea on last replacement date________
- CDR Valve? __No idea on last replacement date_______
- Coolant – last flushed/replaced at __Never done since I owned it___________
- Oil – synthetic/regular, changed at __10k ago_________
- Batteries – state of charge, (matched set) replaced at ___Good__________
- Battery cables and grounds (removed, cleaned and tightened): ____Couple days ago__________
- Glow Plugs - how many miles on them? __No idea_______ What type? _____________
- Injectors - last changed at ___No idea____________
- What were you doing when it happened? ___60 mph on the highway it just stalled out coasted off exit ramp waited a couple minutes and it drove home fine___________
- How was the truck running fine before this problem appeared? ___Fine__________
- Has this problem ever happened before? ___Yes____________________
- Describe any related factors that might be part of the problem. ____Accelerator pedal seems to not work, if I am driving down the road and let off the pedal then get back on the pedal I have to push a lot further on the pedal to get any acceleration or I have to completely let of the pedal and hit it again, sometime I have to push on it a couple times to get it to react__________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __N__ And? __No check engine showing______
Diagnostics:
1] Starting:
1a] Does the engine start? __Yes_______
1b] Does the engine crank over? ___Yes_____
1c] Are your batteries fully charged? __Yes_______
1d] Have you removed, cleaned, and tightened all battery connections? ___Yes_____
1e] Does your Wait to Start light come on for a time? How long? __Yes Normal time 30 seconds I guess_______
1f] Does your glow plug light come on? _________ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? __No______
2a] Can you hear your lift pump working? __Not sure________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? __Haven't checked_______
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? __Haven't checked_________
2d] Loosen an injector line and crank the engine - does fuel come out? ___Haven't checked______
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___No________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) __On intake (FSD heatsink)_________
3b] Condition of Extension harness (if used) Vendor or Homemade? ___Looks ok I greased the connections______
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. __Haven't checked these_______
3d] PMD Make: __FSD_________
3e] PMD Age: ____No Idea_________
4] Stalling Issues
4a] Do you experience stalling only when hot? _Yes___________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) __No____
4c] Does pouring cool water over the IP seem to help with restarting? ___Haven't tried this maybe after a half minute of it sitting it starts back up______
4d] Is stalling momentary (engine recovers)? __No_______
4e] Does SES light come on when engine hiccups? __No_______
4f] Does cruise control quit working when engine hiccups? __Haven't tried the cruise_________
4g] Does re-starting seem to reset engine, restoring cruise and power? ___Yes______
4h] Changes to dash lights or instruments during stalling events? __Yes_________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? __Haven't checked this_____
5b] Any bubbles or oil film in coolant overflow tank? __No_____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? _No_________
5d] Excessive white smoke from exhaust on cold start? __No_______
5e] Excessive black smoke from exhaust under hard acceleration? __No________
6] Performance Issues
6a] Do you have gauges? ___Boost gauge________
6b] Maximum boost under load? __7lbs__________
6c] Have you added a performance PCM (reflash) or Chip? __No____________
6d] Have you changed exhaust / downpipe / crossover? __Yes______________
6e] Wastegate – mechanical or vacuum? ___Mechanical___________
7a] Single or dual thermostats? Not sure___________
7b] Have you replaced them lately? Manufacturer of replacements? ___No______
7c] Have you pulled and cleaned Radiator and coolers lately? __No__________
7d] Have you replaced the fan clutch? Manufacturer of replacement? __No______
7e] (winter) Have you tested your antifreeze? Good to what temp? __No________
7f] (winter) Are you using a winter grille cover? ___No________
Trying to figure out if maybe my PMD or Accelerator pedal is bad or possibly both given the mileage that is on the truck.
Thanks all for your help.:thumbsup:
- Year: __1996____
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
