Will L.
Fuel into the ip, out the return of the ip, nothing coming out the injection lines. Swapped ip with same exact results.
I just want to make sure I understand this correctly.:confused5:
Did you use any of the same parts from old to new ip? Did you verify fuel shut off solenoid working properly? Remove the oil fill tube and verify the pump is turning.
Put a pressure gauge before the ip. Then move it to the return line coming out of the ip. Check cranking with no glow plugs in. Next measure volume of fuel at the same two locations.
