buddy
Active Member
Steve, how much boost are you running while cruising. A TM will set both the max and the min boost, and you dont want a lot of boost when cruising, will take away MPG, so 2-3psi at like 65mph would be good.
A Haa said the blind man now I see;
3:73 & 4x4 may be your limiting factor Steve that and the burbs brick like aerodynamicsATT & a re-tweaking possibly of your Kojo chip to make the most of it, is your next upgrade
If you only set up the TM for 9psi then its probably good for mileage
I wonder if anyone ever tried a turbo bypass system. Just tooling along on the highway, flip a switch and 2 Y valves cause exhaust to go straight out bypassing the turbo, and the engine to breath ambient air. Then you have one engine, choice of turbo or N/A. Just thinking aloud.
You know... there is an idea here. Once I post my how-I-did-my-turbo-master thread... I threaded the stock rod that came out of the actuator. The threading goes all the way down below the bottom of the vacuum actuator housing. It is possible to place two nuts below the housing to create a limit stop to hold open the wastegate a fraction to create the minimum opening on top of the spring maximum boost limiting. Setting that minimum would be nerve racking with only slight turns on the nuts to create a slight opening in the wastegate.
We've really gone off topic from Suburban MPG to reworking of the turbo haven't we?
Thats an interesting idea, so its held open at cruise enough to get low boost, but tight enough to get high pressure at high fuel rate. You would unfortunately lose some spool performance with it not all the way shut at idle.
Are we in great need of boost at idle?
