Acesneights1
I thought 50 koko's also worked on OBD1 ?
Just don't let me near it or it will never run right....:lol:
In a way it was published by GM that you can advance it more. Since the manual states that the TDCO values can be -2.02 to +2.02. The factory timing procedure is just that though, how they set it. Its published in both the area of the manual that provides typical values for each scanner item and in the DTC88 information. However if they had timing checks for these vehicles like they do on gassers during smog certifications then we would have to be -.25 to -.75. It amazed me that the smog certificaion actually required the technician to get a timing light and he failed my buddy's 86 mustang because it had a cam in it that wouldnt run unless it was at 14 degrees, and stock was 12, or something along those lines.
Diesel noob moment:
TDCO?
Top Dead Center O-what?
Offset maybe?
Thanks to the turbo doc for the OBDII procedure, seeing how mine is a 98....
Correct
With over 200K miles on my 94, would a TDC bump be good or bad for the remaining longevity?
