sodfarmer
Movin on up.
Don't know anything about 'em. What are they and what do they do?
You wire them between your power source and the well. It reduces the power output to reduce pressure rather than having to throttle it with a manual valve. The big benefit is not having to check pressure all the time and reduced power usage when not needing to run full volume. They claim a 4 year payback along with the ability to soft start your pump. Ie when you start your pump it doesn't give it all 60 hz at one time it starts slowly and eases up a little at a time.
So far the one on the 250 horse has a few problems it bumps off ~ every 2 hrs. :mad2:
