fancy recessed grease fitting on new u-joints. need a coupler.
GM Guy
Manual Trans. 2WD Enthusiast
NW Kansas and SC Idaho
hey everyone,
I am putting a set of AC delco professional USA made u-joints in the 93 K2500HD.
they have a fitting in one end cap, and it is some kind of recessed tapered fitting. a concave pan head screw of sorts, as you install it with a flat blade screwdriver, but it has a spring loaded ball in the bottom of the concave bowl.
the smallest grease fitting we have in stock is still too big, but maybe if I ordered them in I could convert to a regular nipple, but having more tools and adapters isnt bad, so a conversion coupler would work too.
any input as to where to find a coupler for this fitting? I have never seen one of these things before.
thanks!
My needle greaser looks like this
http://www.zorotools.com/g/00061071/k-G0447501?utm_source=google_shopping&utm_medium=cpc&utm_campaign=Google_Shopping_Feed&kw={keyword}&gclid=CNjN3O7ejrUCFYVFMgodiXoASA
On mine there is a grease zerk inside the end to attach the grease gun to.
sorry jeff, I responded to a loaded page. I did not see your comment.
is it just a regular needle injector? it looks like a needle injector in the picture.
http://www.ebay.com/itm/Grease-Fitti...item2c46c5fa18
Quick Connect Flush Type Coupler
Lets you adapt manual or air operated grease guns quickly to handle all your grease fittings
SImple push on design that quickly attaches to your coupler
Used on Flush type Grease Fittings
The bottom item is more like mine
okay, tried some more keywords on e-bay, and these are the only two things that look like they may work:
http://www.ebay.com/itm/Flush-Mount...pt=Race_Car_Parts&hash=item4aae5a65db&vxp=mtr
http://www.ebay.com/itm/Grease-Fitt...ic_Hydraulic_Valves_Parts&hash=item2c46c5fa18
hey, and then take note of my unchecking of the show signature box. :) it wont be used too often unfortunately.
This is a grease fitting that replaces the regular one on the hose. I don't care for those grease nipples. I got it at a Bumper to Bumper.
