handcannon
Something to consider--you have the dual thermo crossover. This means you don't have the bypass block off that the single thermo has. The theory I've heard, and makes sense to me, is that when the motor is up to temp the open bypass of the dual thermo lets too much coolant circulate back through the block without going through the rad, hampering the cooling process.
Heath recommends a restrictor barb fitting on the water pump for the bypass circuit. This restrictor goes in place of the stock barb fitting and has only about a 1/4 to 3/8ths" opening in it. This allows some coolant to circulate when the motor is cold and thermo is closed, but greatly slows down the circulation through the bypass. I did get Heaths' restictor, but after seeing it you could easily make your own since you are very handy.
Don
Don
