iamdave0887
Here Comes Chaos.....
I'm gonna look at a factory 93 brass/copper rad which has the lines on the right side but no oil cooler. I may have one of those recored. I just returned a leaky one to the junky. I'll call him tomorrow and see if I can buy it back cheap for the tanks and then have it upgraded to 4 core. I really wanted to lose that oil cooler up front too though. I still think getting rid of stuff in front of the rad will make a huge difference. I worked on 2 6.5td owned by someone I know. One is a 94 and the other a 2000. Both are 1 tons and pull heavy equipment trailers. All stock same for PMDs. Stock exhaust everything and neither truck has ever had any overheating problem....why ??? NO A/C in either truck. No condensers...Coincidence ?
I've dragged some semi-heavy stuff with my 96. 10K max when you add in trailer weight. Mine never got warm, not even on a 1 1/2 mile long 7% uphill grade. Was able to maintain 50 mph and keep the TCC locked in 3rd, and the temp needle didn't budge. No A/C in mine either.
I've always thought the A/C condenser had an effect on cooling. It's not even the extra effort to cool the A/C condenser. It's just getting the air through the condenser that's the problem.
