Don't forget the Duramax is not advertised as having 4 valves per cylinder but it does. The valves would be smaller and less area to overheat vs. the big single 6.2 valve. Carbon and hot spots are the reasons for rotors. Smaller valves are cooled better by the stem and seat vs. a larger valve. NOx emissions concerns also dictate cooler peak combustion temperatures as well as lower compression to meet those emissions.
Yet, it isn't about the temperature of the valve as much as it is rotating the valve head away from local hot spots. Imagine the thin spot between the intake and exhaust could be a cold spot from intake air or a hot spot away from coolant in the head.
Single cylinder lawnmowers and other air cooled low compression engines have carbon deposits break loose and bring the engine to a loss of power stop without enough compression to restart when the carbon sticks in a valve. Automotive engines with carbon stuck in a valve will continue to run on 7 of 8 and burn the valve and sometimes the seat. These cheap lawnmower engines need the valves lapped on a regular basis to get the carbon build up off them and reset the wear so they seal good. Industrial Commercial single cylinder engines have these exhaust valve rotors and last longer between service. Valve guide wear is another matter. Interesting that an engine will run with the valve guide worn larger than a replacement valve guide sleeve will fit in - that well worn engine on a commercial use lawnmower has us all standing around in awe.
So two good reason's that valve rotors are an upgrade to an engine for longer life. Life being time between valve jobs.
It is possible that the seat and valve materials have advanced to allow many miles before wear or carbon become an issue without rotors.
So are you going for positive rotation or just free rotation type rotor?
http://www.helical-technology.com/content/view/67/65/lang,en/
