nobby
Old Timey Diesel Guy
Just been reading Alldata on front mount replacement, they list removing the lower control arm at the pivot. Anyone done it without doing that which would be a PIA.
Cheers
Nobby
Cheers
Nobby
IF you could take pix of this job for the stickies would be excellent. I'm sure mine could use a freshening up........ some day...........
Me too. 230k seems like they have done their part.
i had a buddy that used to change mounts with the engine running. stick it in drive, apply a little throttle with the brakes on to do one side and put it in reverse to do the opposite side. kinda dangerous if you ask me, but it works. Ed
Here is what had happened to the oem rubber mounts. The first pic is the driver's side. Pretty normal looking. Notice the gaps on both sides between the rubber and the clamshell. The 2nd pic is of the passenger side. Pretty tweaked inside the clamshell. With the poly mounts there is no room for it to twist like there is with the rubber mounts.A side note. The truck that the rubber mounts came out of has a 5th wheel hitch in it.I have no idea what the previous owners pulled with it.
