EFI Live Announces Cummins Support!
Exactly!
This is what I've said from the get go.
READING the data has never been the problem. FLASHING has never been the problem.
Like I said, they're 7 years behind everyone on that front.
MANIPULATING it without screwing up 10 other things has always been the problem.
When they achieve that, they'll have made progress.
So far, it's not at that level.
Judging from what is posted at COMPD, I would say they just leaped forward that 7 years overnight. The current tables are pretty crude, but the DURAMAX tuning started out the same way. It won't take them long to get these tables to a point where you can fine tune them and be very functional.
update from Ross today
here's an update from Ross @ EFI Live
Hello to all,
It's time to make a public update about what is happening with the Cummins beta so everyone is on the same track and we can stop any internet rumours.
We just released another Beta version to our testers yesterday, this was to check off a minor issue we had with the ECM after it was flashed. The results so far are very good, no DTC's at all once flashed and no DTC's when driving. We found one more checksum that needed to be taken care of, but rather than disable it (like some might) we chose to do the right thing and recalculate the checksum prior to the ECM being flashed.
Anyway, the good news is the the ECM is happy and from what we are told, EFILive now wears the crown as the fastest Cummins flash tool on the market, not only that, it's the only one that doesn't require multiple key cycles after a flash, or, most importantly doesn't erase the VIN!
So the read and reflash side of the Beta for the 5.9L is complete, we can move on.
We also introduced a locking function so nobody can read the tune out of the ECM, this is optional and can be applied prior to a reflash. It won't stop the tune being overwritten, only being read out.
As far as the tuning goes, everyone is getting great results, we weren't expecting horsepower records to be smashed in the first month of beta testing, and they haven't been. But what we did get is multiple tuners saying they have improved the trucks drivability and response enormously which is exactly what we were hoping for.
Over the coming weeks we hope to give the beta testers access to the scantool side of this development. Once they can log critical data the tunes will improve even more and the power will start to climb.
Right now the RPM limit is not being worked on beyond what we thought would be enough tables to provide the solution. Once we get the scan tool working and we can see what is happening with torque, rail pressure, commanded mm3 etc it's going to give us a direction in hunting down the problem. Until then it's just speculation as to the cause, this is why the RPM limit is on hold for the time being. But again, only until the scan tool is functional.
We also hope the scantool data will allow the tuners to get rid of the 'fuel hang' 100%, once and for all.
There was also mention of switchable tunes for them (like the Dmax DSP5). It is our intention to do something like this for the Cummins as well. However, before can figure out how many tunes we can squeeze in to the ECM we need to know what tables are needed when switching.
If there is only 10 tables needed for a switchable tune, then we can probably get more tune options in the same ECM, but if there is 30 or more tables needed (hopefully not), then that is going to take up more space in the ECM which at some point will hit it's limit.
So for the moment, until everyone gets a handle on just what is needed to be modified for a good tune we will hold back on development of a switching tune.
So back to the scantool, below is a list of the sort of data you are going to be able to log from these trucks. From our research there is simply no other scantool on the market that can get all this data.
Cheers,
Ross
A/C Pressure
Balance Rate for Cylinder 1
Balance Rate for Cylinder 2
Balance Rate for Cylinder 3
Balance Rate for Cylinder 4
Balance Rate for Cylinder 5
Balance Rate for Cylinder 6
Barometric Pressure
Battery Temperature
Battery Voltage
Boost Pressure
Commanded Fuel Uncompensated
Commanded Fuel with Balance Rates
Coolant Temperature
Current Gear
Driver Throttle Position
Engine Load
Engine Status
Fan Duty Cycle
Fan Speed
Fuel Control Actuator Current
Fuel Control Actuator Duty Cycle Actual
Fuel Control Actuator Duty Cycle Commanded
Fuel Level
Fuel Pressure Actual
Fuel Pressure Desired
Fuel Pressure Measured
Fuel Pressure Regulator Current
Fuel Pressure Regulator Duty Cycle
Fuelling Scaler
Idle Speed Desired
Injection Timing
Injector Charge Capacitor 1 Voltage
Injector Charge Capacitor 2 Voltage
Injector Control Status
Injector Open Circuit Faults
Injector Short to 12V Circuit Faults
Injector Short to GND Circuit Faults
Injector Timing Status
Intake Air Heater Pre-Heat Timer
Intake Air Heater State
Intake Air Temperature
Intake Manifold Temperature
Main Injection Duration
Pedal Position 1
Pedal Position 2
Percentage of Maximum Torque
Pilot Injection Duration
Post Injection Duration
RPM
TTVA Duty Cycle
TTVA Position Actual
TTVA Position Commanded
Transmission Oil Temperature
Transmission Output Shaft Speed
Transmission Governor Actual
Transmission Governor Commanded
Transmission Governor PWM
Vehicle Speed
Voltage Regulator
Waste-gate Duty Cycle
Water In Fuel
Another EFILive update!
Per Cindy:
There has always been a rivalry between Duramax racers and Cummins racers.
You Duramax guys have always claimed you had the upper hand and that the RPM limiter on the Cummins was/is their downfall.....well sorry guys, not any more.
Below is what we've posted on the Cummins boards today. But no need to get disgruntled or upset - at the end of the day it's these advances that drive competition both the track and generate the aftermarket development. This year's racing season is sure to be unlike those of the past.
It's finally happened, after years of Cummins owners being told it can't be done, the RPM limitation on the 5.9L Cummins ECM has been beaten. We did say EFILive would change Cummins tuning forever, well, here's more proof.
Firstly, EFILive wishes to thank Brayden from Fleece Performance for he's persistence in working with us on beating this problem. When we first hinted at doing Cummins tuning Brayden said to me that he will do anything to help us figure out how to beat the RPM limiter. As he had a test truck with all the right parts as a mule there was nothing stopping us when the time came to give it a go.
With the time zone differences between Australia and Indiana, Brayden often found himself at he's workshop at 1am, 2am, testing changes we'd make over here during our working hours. Well finally we did it, and at some insane hour of the morning in Indiana you may have heard their shop truck screaming to 5,300 RPM.
It's not a 100% perfect run, the injection is maintaining over 100mm3 of fuel up to about 4,200 RPM, but starts to taper off above that, still, this is a minor set back we will keep pursuing and it may be something as simple as another table that was never calibrated from factory to fuel that high.
This RPM Limiter fix will not be available in our first public release, but it will at some point be available for everyone.
Below is a screen shot of the scantool from this run.
Cheers
Cindy
A quick video:
http://www.youtube.com/watch?v=bv8AxOU7IRg&feature=player_embedded
