EFI live 90-100hp tune
chevy*tough
Thorp, Wisconsin
What tables do i have to change to make a decent 90-100hp tune....Thanks and want smoke cloud at start up<<<might have it figured out smoke cloud is just the cranking table!
add some timing maybe paste the timing table from table A into... I think table C ( C being the main table used) and add a little fuel. that should get you started.
be careful with the cranking injection quantity. if you make it to high to get a nice cloud on start and it doesnt fire quick enough or you let the key go to quick you will be priming the system. i had mine high and it happened on more than one occasion. it becomes natural to let the key go because you learn your truck and it drained the rail of fuel and i dont have a lift pump so i was manually pumping it.
