Progress so far...
First oil hose for the turbo was unusable. They gave me an oil fitting for the turbo to replace the one on the turbo do to being out of stock of the proper fitting. The A-Team turbo has a different thread on the oil hose adapter than the stock turbo.
New CPS installed, just because we were there, and yes it is a biotch to get out even with the timing comer removed from the engine!
Note the A-Team turbo is HUGE vs the GM turbo. Turbo blanket next as well as wrapping the down pipe. This header wrap is painted with the header coating/sealer paint.
Note the injector/ heat shield / manifold clearance issues with 2 exhaust gaskets. 6.2 heads off a 1986 year. 6.5 short injectors.
