The frustration continues...... Gonna need some help with this one. It ran good for a couple of days so I decided to try out my new PPE tuner. I chose position 2 tow haul (90 hp increase). It ran great after, in fact I was pretty impressed with the throttle response, the increased acceleration, and improved tranny performance. I also installed an EFI live monitor. It does some diagnostic scanning, OBDII code reading and clearing, and engine gauges. So I checked inj. balance rates all were in spec.(2,5&7 were on the hi side but still in.) A couple of days later I got back from the store, put it in park, left it idling, and about 5 min later she started running like crap. I mean knocking,misfiring, the works. Checked the inj balance rates, they were all over the place, and I had no new codes Shut her down, then restarted it, and it was back to running fine again! So now I,m thinking, it reset itself, must be something to do with the FICM, ECM, or their connectors. But I have no codes. I removed the tuner program and put it back to stock. Checked all rellevant grounds. All good Checked the wiring, found one of the pink FICM ignition wires chafed through at the camlock connector on D/S. Repaired. Even did the "ice pick" trick on the inj connectors. The problem isn't as bad. While going down the road its fine, it doesn't go into a fit until it is stopped and idling . Any thoughts? Please help me. My poor old brain is turning to mush! LOL
