racedaymechanic
Active Member
FINALLY HERE THEY ARE $325.00 + Shipping, Stainless Steel ARP Bolts included
1000F Heat Sleeve
Starter end
1000F Heat Sleeve
Starter end
You're gonna make me broke with all of these goodies! Very nice and the price seems good!
Will those ends fit over the screw on posts of marine batteries?
my guess is yes, since all I did to move my side terminals to those was to remove the side terminal bolt from the center...
my only concern is if there is enough slack to reach to the marine posts...Mine are stretched to the limits and "barely" make the hookup...
I'll get a pic of what my setup looks like...probably redundant because you probably already know what a 34/78 series optima blue top looks like...
Common Guys Business is super slow I need to sell some of these
Not me!Well, you know Bruce, those DMax guys have payments.:hihi:
I dont do a larger box but I run a 2 gauge cable to the box, but not back out so it frees up 1/2 of the boxI'll get those measurements for those posts by the weekend...
out of curiosity...can you get a larger red box(jump terminal) to where I can fit all my connections in?
just wondering is all...
Yeah shoot me a pic and a measurement from the edge of the post to the edge of the battery so I can see if I can use the 90 degree ends or 45
finally got around to taking a picture...using a quarter for reference
as you can see the wires are stretched and are on a 45* angle instead of at a 90* like they were stock...same on drivers side, I would guesstimate around 4 inches minimum to correct both the angle and to come on top of the battery...not sure what your 45* end looks like..or if it would reach to the end of the battery before angling down some... if you need any more details, let me know...
