Dura-Ration at the drags
That 30 feet would equate to .253 seconds assuming you were no longer accelerating. => It would be a little less, without knowing what v2 and v3 is I can't figure that, but about .25 sec is a good kitchen physics guess.
I came up with .45454545454545454545454545...but I don't know that much about math or quantum physics...
I wonder how the NHRA seems to come up with a 1.6 conversion factor from the 1/8 to the 1/4 mi where as Mine seems factor at 1.57 consistently...(my true 1/4 passes if using my 1/8 mark times on the NHRA conversion would be 13.22 when it really is a 12.977)
that's why I don't believe in conversion tables and only use them as a base line...
Thank you Wrecker. So my time is about 7.92 Great that beats a certain LBZ on this site. ):h But I'll make it to a correct length strip soon to prove the time.
Try this one Pep
1/8th to 1/4 Mile Et Calculator - Wallace Racing
I just tried it with Wreckers info 7.92 and came out with a 1/4 mile time of 12.43 Now I don't believe it either. Gee's, But it would put me in the White chrome area of drag racing.):h
No way
Wow that sucks. I won't post what that comes out too. Until I get my Whitechrome award for my other times posted above. ):h Where did you get that 1.57 number from,anyway ?
:You_Rock_Emoticon:
I'm running a FULL 1/8th just like a drive it every day with a best of a 1.8 60ft. I need to lower my bars, spring clamps, etc and go back to get another number...
LBZ's can put a 7.8 easily with the right suspension work. That's a 12.5 1/4 time. (Kat's LBZ)
:You_Rock_Emoticon:
So your saying LBZ's are Faster than LB7's ?
but you were running slower(techniques) when you were running the 1/4...so it doesn't count...
try adding the .45(30' compensation) to your short 1/8 times and then multiply by 1.57 ... I get 12.91..may be slower than your actual 1/4 times...but who knows...
I got the 1.57 number by plugging in different #'s between 1.56(some other calculators) and 1.60(NHRA)
and multiplying by my 1/8 times... when I found the number that consistently equated my 1/8 times to my actual 1/4 times I used that against all my time slips...and consistently 1.57 was by far the closest factor on nearly all my slips...
try adding the .45(30' compensation) to your short 1/8 times and then multiply by 1.57 ... I get 12.91..may be slower than actual...but who knows...
Ok. Where did the .45 come from. Wrecker came up with .25 , I like his number better.):h
I just used some old fashioned multiplication division and subtraction... using a mental slideing scale the represented the gradual loss of quickness(the 1.57 factor) between the 1/8 and 1/4 but equated from the amount of foot difference (30' in comparison to the 1/8)
It took a lot of thinking and doing...and I'm sure what i typed doesn't really fully describe what I did(confused you more<and myself> probably)and I'm not saying it's right...but that's the factor I came up with...
thats why I made the disclaimer about physics and math...
I do know for a fact that for my trucks 1/8 times multiplied by 1.57 is pretty spot on with all my 1/4 slips...
I'm sure every truck is different so maybe when you get a bunch of 1/4 slips with your newer more consistent times we can figure out if 1.57 is right for your truck too...:thumbsup:
