DTC's, Cal resistor range, DS 6.5, DB2, 5.7L, info online from Stanadyne!
WarWagon
Well it hits on 7 of 8...
AZ
Looking for the EID assembly elastomer insert drive info and what year it affected of the DB2 pumps to clarify a post of mine for "Ratman" I came across this goldmine.
CMY: The Google search I used. :agreed:
1st result:
Oldsmobile 1985 doc referencing EID governor here:
http://www.stanadyne.com/dealerportal/ssi/english/Service Bulletin/400.pdf
Why you care: Surplus military or other DB2 equipped low mile engines could still have the old design that are known to fail.
DS troubleshooting. Calibration resistor ranges. DTC codes. No, not just the DTC's with stupid one line errors, but, a paragraph of conditions that cause it to set! :thumbsup:
http://www.stanadyne.com/dealerportal/ssi/english/Service Bulletin/500.pdf
Attached as DS4 cal resisters...
Now you can understand how complicated the pumps are and why you want a Stanadyne dealer to work on yours after your troubleshooting has left only the IP or injectors. That and balanced injectors from a Stanadyne shop: none smoother running...
  • olds db2 400.pdf
  • DS4 cal resisters 500.pdf
  • EID 426.pdf
