matuva
Tropical 6.5er
My rig is lightening the MIL ON, throwing a DTC35. She does that especially in the 5 minutes following cold start, at acceleration.
The MIL turns Off if I release the accelerator OR if I floor the pedal, WOT...
At cold, no or slight vacuum in the tank. Untill the past days, she is now experiencing difficult start when cold: I have to crank a long time, sometimes 2/3 times, before she finally starts. When she starts, the engine spins slowly first (probably around 2-300 rpms), then accelerate up to the nominal 6-700 rpms, roughly, with white smoke.
After few seconds to 1/2 a minute, the engine runs smooth, but at normal iddle speed - 650 rpms-, same as if it is hot.
IP is only few months old, it's a brand new 5521S. I have a DAHL 65 fuel water separator with a transparent bowl, so I can see no air before the Fuel filter manager
Lift pump is a FRC-10, on which I just cleaned the embedded filter. Yesterday, just before starting, I hot wired the LP, and.... nada. I plug and unplugged the hot wire several times, nothing.
I kept it hot wired , then the lift pump started itslef...
During the day, after this morning start up, engine starts easy, no MIL On, no white smoke...
I'm a bit at lost...
