Big T
WAG= could the PCM be WG programed instead of TM programed= WAG
Or just have a BAD WG solenoid plugged in.....and it's making the PCM angry?
Not clear on your acronyms. WG = Wastegate?
If so, Bill was clearly instructed that I had an ATT. He was staring at the program while I was on the phone with him and it's for an ATT, that is non-wastegate.
As noted in my prior post, I borrowed the wastegate solenoid from Colbythekid's '95. That solenoid is known to be working as he still has the vacuum operated wastegate AND I had changed the solenoid about 1.5 years ago when the original failed.
The only things left are the PCM and wiring. I further cleaned the ground connections to the passenger side frame today. They were already clean. I'll do the same at the firewall. Really running out of things to do here. This has become more challenging (though less problematic) than my rotatable CPS episode on the '95.
