Pepperidge
Member Advocate
Glad someone enjoyed it...I was beginning to think you 6.5 guys didn't have a sense of humor...:biggrinjester:
I put it in the same way the one that lasted 30k miles. The lip side facing the diff and the open side toward the bearings.
Goldsburg said:Isn't there a "Drivetrain" forum somewhere on this board?
Probably, but it's likely full of DMax guys ... 6.5 stuff tends to get lost in those forums, and they attract all kinds of misinfo. (like the guys who wanted us to forego the TCC lock mod in favour of just pushing the Tow/haul button)
I know what you're saying, Golds, but I tend to like my 6.5 stuff all in one place; I'm not too smart, and I understand it better that way.![]()
...like the guys who wanted us to forego the TCC lock mod in favour of just pushing the Tow/haul button...
Damn! My new seal is leaking. I think my e-brake is too tight. The driver side is tight and the passenger side doesn't seem to tighten. I lossened the adjustement so hopefully that will do the trick.
Try a speedy sleeve next time you go through this. It's easy to install and will probably take care of your problem.
What is a speedy sleeve?
It's a very thin sleeve that slips over a shaft, thereby it creates a new wear surface for the seal to wear on. Leo
Been a while since i did one,have a look at the fillplug location, it might be below centerline of axle. if it is then with vehicle level the oil will stay in the pumpkin and not run out of the housing ends.Well I finally got around to fixing my leaky seal. After talking to a friend of mine who has done quite a few of them, he thinks I didn't seat the bearings all the way when I replace the bad seal. He also took a look at the axel stem and said it was good and wouldn't need a sleave. I got it all buttoned up and went to top off the diff fluid and it dribbled out when I opened the plug. With the amount that came out when I replaced my sill it should need to be topped off. I topped it off the last time so could there be excess somewhere it the axel somewhere. I am baffled
