mfgguru
Makin' it better!
Well, I finally felt called to make a turbo master. It's been on my mind for a while, but you know how it is, sometimes you just don't feel like it. Anyway, I used the original wastgate actuator(why re-invent the wheel),
5/16 threaded rod with flat washers,
a 5/16 nut with nylon locking capabilities.
The spring I used was a 5/8 by .080 thickness, 2.5 inches long. I thought the long spring would make for better adjustability and response and allow good movement.
Didn't take very long and was really easy.
When I get to my lathe a work, I am going to make a centering carrier for the top and bottom of the spring to keep it cetered.
Set as it is, it peaks at 11psi and has a sustained pressure of about 5-6psi.
Tools used: Socket set, flat screwdriver, angle grinder, welder, drill and drill bits.
Hope you like, I know lots have already done it.
Cheers,:hat:
Mike
PS: you can see where my vacuum line failed. POS!
Cheers,:hat:
Mike
