So all this testing is done at the harnesses at the balance module, or do i need to do this at the rear tank?
Don't expect results too quickly, i don't go home too often. I should really use this as an excuse to finally buy the video camera and computer that i have been wanting for a while. it would be kind of cool to take a video.
To tide you over till i get around to it, i personally would wire up a toggle, unless you don't want to hack and wack on the dash or wiring.
PS, with the auto, we have had great luck routing wiring in and out of the cab with a hole the PO bored right in the middle of the round plate where the clutch goes in a MT truck.
Thanks you sincerely.
All measurements at the balance module. Unplug it and test the 2 pins on the harness with all the wires. very easy, clean and simple. Easy to access too.
I'm in no rush. Mine reads 35.5 empty. Which doesn't make sense because everything I read about GM FSU's say they are 0-90ohms.
My thinking is the factory fsu for stock dual tanks do not have a normal 0/90 readout.
When I fill my tank up, gauge goes down to 1/2, and when its empty it goes to full.
GM also didn't use the same FSU's for dual tank vehicles. My thinking would be they would if they could have to save money. So perhaps they different.
What are the odds... Dual tank 6.5. So now I'm 1%, of 1%..........
GM GUY, My balance module does xfer fuel properly. It's my fuel gauges I'm trying to fix.
Ran out of fuel today, or was about too, it limp moded, when it does that I know I need FUEL NOW, or suffer.
I always keep 10 gallons or more in my xfer tank, so I just pulled over and pumped it in.
GS gauge was teetering on the FULL mark. So now I have a useable fuel gauge. Just reads backwards.
GS has a their own forum for tech support, I posted in there and we'll see what the results are.
Here is my latest thinking, if the 2 wires coming out of FSU are reading and ground, what would happen if I grounded the reading, and tested the Ground for OHMS? Would I get the opposite?
cold wet ground is coming, so if i don't get this resolved I will in spring.
I'm sure the diesel gods have plenty of other things lined up for me to lay on my back in the wet slushy roads, getting dripped on.!!!!
