tinman
How much does the ohm reading change? Most likely when the key is on the module is activated and both tanks are connected as one circuit, when it's off they are separated again.
I have my rear tank on a toggle now and it works great that way, I have it hooked through the factory wiring though so if the engine isn't running then it will only run for a short time. I figure that is safer than someone forgetting the switch is on and having it run until the pump burns out.
