RayMich
I have a 2006 GMC LBZ with the Allison 6-speed transmission.
The truck has been serviced by me religiously approximately every 7500 miles, the Allison external oil filter was replaced every time and about a 1/2 pint of Dexron VI was added to replace what was lost in the external filter.
This truck is 100% stock and now has approximately 62,000 miles on the clock. It has never been raced or abused and the only trailer towing it has seen has been a couple of hundred miles towing a 1,500 lb flat-bottom boat and about 500 miles towing a U-Haul trailer weighing in at around 2,000 lbs.
I did have some small transmission oil leaks TWICE but The oil level never dropped to the ADD line before My GMC dealer replaced all of the transmission cooler lines. The dealer had to replace approx. 6 to 8 quarts of transmission fluid every time they replaced the oil cooler lines. (At least that's what I remember seeing on the repair ticket) The last time was two years ago and I have not had any leaks since then.
At 4,300 miles I changed all fluids to Mobil synthetic oils except for the transmission oil. The transmission oil was replaced with BP's TES-295 approved synthetic oil at around 52,000 miles.
Seven and a half months ago (approx. 10,000 miles ago) I had the transmission serviced by an Allison shop but not a GM dealer. I had the transmission oil replaced with BP's Autran Syn 295 synthetic oil which is TES-295 approved (TranSynd equivalent) Less expensive than TranSynd but still expensive.
The transmission was flushed at that time per the "Hoot" procedure and new internal and external oil filters were installed. Inspection while the pan was off revealed no clutch residue in the pan and a healthy transmission.
Although I don't think my problem is related to the transmission being serviced, I have included this information to give a better history of this transmission's usage and service life.
Shortly after the transmission was serviced, I began to experience a delayed downshift clunk when coming to a stop after driving only about 1 or 2 miles, but this would generally go away when the engine and transmission warmed up.
Lately, I've noticed this delayed downshift clunk much more pronounced and it does not go away even after driving for for 10 to 15 miles.
At first I thought the problem might be the brakes, but when I move the shift lever into neutral before stopping the clunk is not there. However, when I stop with the transmission in gear the downshift clunk returns.
I have not experienced any CEL during this time, but I admit that I have not yet checked for codes with my scanner.
The truck is still under the GM Extended Protection Plan (This extended plan is good until this coming December)
Any comments and suggestions to help me try and figure this out will be greatly appreciated.
I would take it back the the Allison shop that serviced the transmission, but it is 130 miles and two hours away, so I'm hoping to be able to figure this out without having to drive that far.
Thanks.
Thanks.
