ak diesel driver
6.5 driver
Yes ours are externally balanced so they need everything
Thanks, Les. It's the same, but just with a few more miles on the ticker. It doesn't see salt.Does your truck still look as good as it used to Snowdrift? IIRC it was really clean and a sharp looking truck.
Just make sure they don't get the engine from Bostic or Jasper.Accurate (link above) gets $4700 plus core charge. Remanufacture. Nothing special, but he said they cover all the bulletins, etc. that were supposed to have come out on the engine - maybe not worth much since I doubt GM or Detroit would admit to some of their past sins. Three year/100k mile warranty, then indefinite warranty extension for $80/year thereafter. Supposed to have new timing set and multiple other new internals, some things checked. Crank turned - this bothers me, based on the stories I've heard.
They're also pretty close on timeframe - few weeks.
This actually sounds pretty attractive, but I'd want to see a copy of the warranty papers up front to see what the limitations are.
Nothing available from Pace
I glanced over this a time or two, but admit that I discounted it after seeing the author was doing the work outdoors under a tent. I just didn't take him serious. When doing searches for certain subjects, it kept popping up, so I decided to take a further look, then another, etc. It turns out that this guy seems to have really captured some details with his engine build. He made mention of Will and a few others, which I hold in high regard on the subject, so this got my attention. I did find where it had been linked before, but thought I would link here, as well.
GM 6.5 Diesel Performance And Durability Tips For The Do-It-Yourselfer
You can get much more power AND long life out of your GM 6.5 diesel and you can do it in your own garage with our how-tos and videos here...www.65turbogarage.com
At what point should head studs be considered? It sounds like an HX40 might be in my far future, simply for better mileage, but I'm not going after 20 psi boost, so is it something to consider or just put in new bolts and leave it alone? One major concern has always been whether or not the heads can come off without pulling the engine if that had to happen, if a guy uses studs on one of these.
