625fireman
I have injecter-itis
Mine did the same thing and I found the ground wire to the frame from the firewall wa sbroken off. It is down on the fram by the down pipe. You might have to move rubber flap on the inner fender to see it.
What is up did my injection pump quit? Will go out and pull some injector lines.
CPS and OS you mean crank position sensor and optical sensor right?
