dbrannon79
I'm getting there!
the fuse for the GP controller is under the hood, at least mine is. it's labeled something like "ECM-B" iirc. and Ak is right. you may have gotten the IP close enough for it to run, but once the ecm looks at the current timing which is usually every 50 key cycles or so, it might leave you scratching your head as to why all of a sudden it runs out of whack!
