Stuka T
- Messages
- 11
- Reaction score
- 34
Hello Truck Stop, I own a 1996 GMC Sierra K2500 with a 6.5. 235,000 miles on it. Truck has been running great since I bought it at 105,000 miles. I replaced the transmission, had the front end suspension rebuilt. Original PMD crapped out at 190,000 miles, I put a remote unit on the side of the engine compartment. No codes at the moment. Pretty sure I blew out my ignition pump a month back and I wanted to tell the saga here and see if I’m right to plunk down $1,200 for an Accurate Diesel rebuild along with a new set of glow plugs and injectors.
I had just over a quarter of a tank and felt like I was running out of fuel all of a sudden. I was on a country road with no shoulder, so I nursed it roughly a mile and a half at 3 to 5 miles an hour until I could safely pull over, with it progressively running worse and worse. I figured somehow I WAS out of diesel and the gauge was screwed up. The next day I went back with five gallons of diesel, primed the fuel pump, checked the T bar up front, both sprayed an ample amount of fuel. Truck would turn over just fine but wouldn’t start. I had it towed to my house and have been messing with it ever since, with no luck.
The front hose on the pump blows a steady stream out when I turn it over, so it seems the lift pump is working fine. FFM and t bar both still blast fuel when I jump them at the fuse box. I’ve pulled all fuel lines at the injectors, four are getting a small trickle, the other four are getting nothing at all. None of the mist I keep hearing I should be seeing. I immediately bought a new Echlin PMD from Napa to be safe. No results. I also put a new starter solenoid on the ignition pump, in a Hail Mary pass. I have an Oil Pressure Sensor on the way from Amazon, but it seems that with fuel coming out the T bar and front injector pump hose that everything at the rear is flowing fine. The fuel is grinding to a halt somewhere inside of the injector pump, and barely making it out.
I’ve checked all grounds, replaced all fuses. Both batteries are a year and a half old, I’ve kept them fully charged. I’ve plugged in the block heater. Don’t see the security theft icon on the dash console. Wait To Start light flashes during ignition, so does the Check Engine light. Recently I’ve noticed a Check Gauges light on during ignition, that seems new.
I’m a dilettante mechanic wise, though I’ve noticed modern day mechanics are not the maestros of yore. I've done OK with the repairs I've attempted. It seems all signs point to the ignition pump crapping out at 235,000 miles, which apparently is 85,000 more miles than the average. I'm baffled that my Bosch code reader isn't coming up with anything, and there has been nothing in the way of Check Engine light. Tomorrow I’ll try to pull off the Optical Sensor as some have mentioned, and see if that throws any juice into the empty lines. But that and the OPS are the last gestures I’ll make before taking The Big Plunge. I've read about ECM and vacuum lines, maybe some more advice will inspire me to dig deeper into those possibilities. I really need my truck to get back to work.
Anything I missed? Accurate Diesel seems to be a haven for 6.5 owners, are their rebuilds decent quality? Seems like everyone is out of Bosch injectors at the moment. I see there are ignition pump swap instruction vids on Youtube, and feel I’m better off chancing it myself than paying a shop $130 an hour.
