Acesneights1
Drove about 40 miles, all hwy , to a horrible truck pull. Then went to a place to get boots. Pulled in the parking lot and the truck was idling funny like cutting out. I raced it up and it seems to clear a little. I noticed the speedo was bouncing around a little while it was idling weird. I shut it off and it hesistated to shut off. Went in and got my boots. Came out crank but no start. Opened the bleeder on the FF and it had residual pressue(I was bymyself). No test light but with key on took wire off IP a few times and saw it sparking like it was getting power. Went back in with foot to floor and it finally started as the POS interstate batteries nearly died(Those gotta go).
No smoke that I could see, was still idling bad and had to kepp it raced up a little to keep it smooth. Drove 40 miles home with no problems, plenty of power and it's running fine now. I'm at a loss here. Maybe I should have went to church with it again. I think this thing may see the torch yet. I'm losing patience quickly. Grounds are clean cause I cleaned everyhting up when I had the heads off a few weeks ago. All I can think of is ign switch, LP or IP. When it was idling rough it felt like someone was cutting power to the IP quuickly. Is the IP power looped through the ecm in this thing or come directly from the key ?
Followup:
I tried to start it a little while later and no start. I ran a jumper from Batt to the IP ESO. Still no start until I cranked the heck out of it with my foot to the floor and it finally came to life but was acting like it had run out of fuel, was idling a littel rough and then cleared up Shut it off, started back up . No fuel leaks along the chassis. Either the Mech LP is going or the IP I got is junk.:mad2:
I'm going to grab a LP from Auto APrts tommorow, stock replacement for 93 6.5TD. If that doesn't do it I guess the IP is coming back off.
Followup:
