DB2 Interchange
I don't have a problem changing it out to a 12v set up, But I do need to get running as " cheaply " as I can...
One I get it switched over and running, I'll be listing the ds4 pump and ecu in the classifieds...
Ok so pump just came into day.. Ohm'd it out and across the top its 112.x the wires don't read anything...
Called the closest Stanadyne shop and the 12v solenoid is $110.x plus tax; A basic rebuild is around $850.00... So yeah if i can find a 12 to 24v converter cheaper than I'll go that route....
