Can anybody explain what the differences are between a regular and military 6.2 6.5 pumps?
From what I understand the milspec ones have 'hardened" internals so they can run whatever fuel is available; I've also heard the 24v thing, but then I've also heard that "just" the starter is 24v and everything else is 12v.. Also will the injector lines mix and match? I understand that DS4 and DB2 lines won't, and that you have to use a full set from whatever pump I.E. all from a 6.2 or all from a 6.5; But other than that is there any reason why they wont?
Also any reason why you cant just use a transformer or a relay to get 24v if required for the pump, Bobby said that a Stanadyne Service Center should be able to change it over relativity cheep; But for some reason Google does not like me right now to be able to find one...
