HighSierra86
Started amassing parts a few weeks back and finally have everything I need. I think. Read through Bobbie Martin's guide he graciously made available. Most of his listed part numbers are no longer available from GM or anywhere else for that matter. The throttle cable proved to be the toughest find so far.
Anyways I've completed the tear down and have finally started putting things back together. Found a lot more work for myself during the year down including alternator bearings, seeping water pump, and some oil leaks needing attention. Also found the source of my recently acquired excessive turbo lag!
Purchased a rebuilt DB2 4911 with full updates including the rotor head. I had priced brand new, but at $2000 I just couldn't justify it being that much better than a high quality rebuild. Sure looks small next to the DS4! Even though it would be perfect time to reach in and turn the screw, I'm leaving it in stock form for now to keep the warranty until the truck is up and running and all the bugs are worked out.
Nick
