largelybored
Hi all,
Recently the IP on my 1998 C2500 Suburban went out. I've been quoted about $1900 to install a new DS4 w/stanadyne PMD by the local Stanadyne shop. I'm trying to come up with the cost (parts and labor) for doing a DB2 conversion. So far the parts come out to $2200 or so. (Scheid reman pump, hpca sender, injector lines, throttle cable, optishift, kennedy turbomaster, TPS). I still need to source the bracket and pedal assembly.
I'm in the process of trying to find a shop to give me an estimate on the conversion. (I can't do it myself)
I've read Bobbie Martin's guide, and to avoid the TCM wiring issues, I decided its probably easier to buy an Opti Shift.
I'd like to solicit people's thoughts on solving the dual thermostat + throttle bracket problem.
Some folks have modified the throttle bracket. I know one forum member did so, but he's got a NV4500, so he has no need for a TPS. I'm not sure if you can shave the bracket if you need the mounting holes for the TPS. Another member put on a different upper intake and rotated his thermostat housing to get the clearances.
Other folks say you can go to a single thermostat housing.
Does anyone else have any creative ideas for solving this problem?
I'd like to have the capability of putting on an electromechanical cruise control, I'd like to keep my two thermostats, and I'd like to have the simplest, most capable solution.
At this point, I'm thinking turning the thermostat housing around and changing out the upper intake to what I think is the van style may be the best option.
-LB
-LB
