Husker6.5
Thanks man. I'll have to take a look at what they output for a voltage because a little adapter would be a joke to track down.
They're Bosch and run with the Bosch fuel injection computer on the TDI's if that helps you any. Don't know much of the technical end of them, just read a review on the Euro-spec Golf TDI GT in the May Diesel Power, and it mentioned that VW used a combination glowplug/pressure sensor to monitor in-cylinder pressure and optimize the injection command from the CPU to each injector for cylinder balance and optimized mpg. Just sounded like a possible better mouse trap for what you wanted to do. Wouldn't it be giggles and shits if they just screwed right in and talked to your data logger out of the box?
