Rockabillyrat
SlIgHtLy StUpId.
As I get closer to my engine build I've been spending some time researching head flow CFM and camshaft profiles on the 6.5. When upgrading to a much more efficient turbo I wanted to see if improvements could be made to the engine to make the most out of a turbo upgrade. So I took the time to locate head CFM and cam specs from other diesel engines as a comparison. After all an engine is just a giant air pump, and air doesn't care if its DI or IDI. I was very surprised by what I found and it completely changed my opinion on porting 6.5 heads. I figured some of you might be interested in this information.
CYLINDER HEAD CFM
ENGINE- INTAKE CFM/ EXHAUST CFM/ VALVE LIFT
6.5 - 175/145/@.500
7.3 IDI - 187/163/@.500
7.3 PS - 110CFM
6.0 - 162/122/ @.500
12v - 143/151/ ?
24v - 156/169/?
LB7 - 183/149/@.500
NOTES:
* According to TSP chart the 6.5 did better on the intake at .450 lift (180cfm)
* Could not locate any more info on the 7.3 PS
* Alternate specs for the 12v 131/139/@.500 maybe this is with the integrated intake have not been able to confirm.
* Some claim the 24v does 185cmf stock
* For comparison a ported 12v head flows 184/195/@.500
I was surprised to see how well the 6.5 heads compare to the rest. Especially with the power levels I know the other platforms make with stock heads. . For my build I'm thinking of leaving the intake side of the heads alone, with maybe some slight exhaust port work. Then upgrading to 1.6 rockers to get a .450 net valve lift to max out the flow of the head. Now on to camshafts...
CAMSHAFT
Intake Duration @ .050/ Exhaust Duration @.050/ Lobe Separation Angle
6.5 - 178/201/110
7.3 IDI - 176/184/103
7.3 PS - 177/185/104
6.0 - 167/176/106
12v - 159/204/102
24v - 159/206/107.5
LB7 - 176/176/106
NOTES:
* I found 2 different LSA for the 7.3 IDI once source said 103 the other said 105
* For comparison a stage 1 performance 12v cam is 175/210/104
Again I was surprised to see how the 6.5 compared to the rest. The only thing that really sticks out is the wide LSA the 6.5 cam has. I assume this is because the 6.2 (same cam as the 6.5) was a N/A diesel and they wanted a wide torque curve to go with its 4400rpm operating range. Then once they added a turbo the LSA was also beneficial to deal with the high drive pressure of the stock GM turbo. But with a more efficient turbo I think the LSA could be knocked down to 108 maybe even 107. Most performance diesel camshafts are in that LSA range.
I'm sure some of you will rake me over the coals for this. But my unpopular opinion is that the stock heads and cam are fine just the way they are for 99% of 6.5 builds. The CFM you gain from port work, big valves, and high ratio rockers doesn't make much of a difference on a turbocharged engine. That extra CFM can easily be made up with a turbo. Port velocity is more important than CFM to a point. Obviously your not going to make 1000hp on heads that flow 100cfm. Its a balancing act of CFM, and port velocity to have a responsive engine that makes your power goals in the RPM range of you engine. Look back at the muscle car era, they proved big heads+ big cam+ big carb = port stall and the car was a dog off the line.
To my knowledge these specs are accurate, but if anyone sees something that's wrong please let me know.
CYLINDER HEAD CFM
6.5 - 175/145/@.500
7.3 PS - 110CFM
12v - 143/151/ ?
24v - 156/169/?
LB7 - 183/149/@.500
NOTES:
CAMSHAFT
6.5 - 178/201/110
6.0 - 167/176/106
12v - 159/204/102
24v - 159/206/107.5
LB7 - 176/176/106
NOTES:
