Anubis
Being fat sucks
Ok now I know this will be a PIA, but I need to see under those dead sexy rocker assemblies to see how the blocks fit together and how the head was machined ....... I am going to have my Machinist do this ...........
I don't know the brand. just BBC 1.7:1 stainless steel roller rockers ...... look like yours 'cept they have not been drilled for the shaft. new in box $145
the add does give the brand.... I just can't recall it
Mikeys rockers are a BBC unit with the fulcrum removed. There are two roller bearings pressed in each rocker that rides on the tool steel rocker shaft that were surface hardened to prevent brinelling- or wearing grooves.
The mounting blocks were also hardened due to the rockers being guided between the snap rings and blocks.
I read this in another thread somewhere. (edit: it was THIS thread... )
Beware of cheapo rockers...
Did you check lifter preload ?
If it were me I would modify the oil pan, notching the cross member would weaken it.
Is that the height the block will be at when it sits in the motor mounts?
