great white
Its holding up well. the cummins is dependable and strong running lots of power to haul anything. i worked out the clutch hydrolic bugs. the only complaint i have is the nv4500 i toasted 3rd gear syncro. when i get the time id like to swap a medium duty 5 speed in. i work the truck every day it earns it keep, it has some rust i need to adress and i have to decide if i want to patch the crack in the frame or find a donor truck. i cracked the frame hauling a large tractor. after winter there may just be another swap into a long bed or dually. its proving difficult to find a truck perfect for my re swap
Don't buy a truck from the rust belt east coast if you want a swap that will last. Head west to the interior and pic up a rust free truck.
It sounds like more money, but it's actually less in the long run.
My 98 comes from a relatively rust free area of BC. You can still pit a wrench on the shock bolts and turn them out with ease. No smoke wrench required.
I'll never buy another rust bucket again....
