SmithvilleD
Active Member
Fabricated a rear mount bracket, fitting my '95 6.5, to upgrade from the stock CS-130 to the CS-144 alternator. There are several threads about doing this; thought I'd share what I came up with as well.
I wanted something that kept the triangulated support the OEM rear bracket for the CS-130 had. Drew up a template on cardboard, then used my portaband saw/table to cut a "C" shaped piece that mates to both available mounting bolts on the back of the CS-144 & also ties in with the bottom/front alternator mounting bolt. The C shape is made out of 1/4" hot rolled steel. Decided on the C shape so as not to restrict cooling airflow to the bridge rectifier.
From the OEM rear bracket, I cut off the portion that's bent to vertical & mounted the back of the CS-130. The cut was made so what's left matches/fit where the back of the C shaped bracket sets, with the alternator mounted. Tacked this in place, then added a short piece of bar stock to reinforce the 90 degree joint where the C shape & remains of the OEM rear bracket meet.
The 2nd mount is simply 1/4" x 1" bar steel with hole centers drilled a bit shorter than the OEM CS-130 strap. I'm still debating if adding a piece from the front of this upper alternator mount to the front of the belt tensioner would actually add enough useful rigidity/strength to be worth the effort? It would mount the upper alternator ear in double-shear, but the tensioner itself mounts/bolts only from its rear to the cast engine accessory bracket.
