knh208
I've owned my 6.5 for a shade over 5 years now.
Last year in February, I moved my PMD from the pump to a heatsink in the bumper. I used a chitty EDAM cable that worked poorly at best. Cost me a $50 tow, a week of diagnostics in the driveway, and eventually a new cable.
Even with all of the troubles that I had with that cable, the cruise control always worked until the truck stalled. The truck was stalling because the cable was garbage, and would lose connection. All I had to do was open the hood and bend the cable around a bit, and it would start right up again. Still a major PITA!
After the new cable arrived, I drove for a couple weeks without any issues. Then, while driving along one day, cruise control would not engage. I started by checking for voltage to and from the multifunction switch. If you ever decide to perform this type of check, be careful with the hazard light switch sticking out of the top of it. Ask me how I know... Long story short, voltage was good in all positions.
The next thing that I did was check voltage to the PCM while swapping in my Heath GL4. I get voltage to on, resume and set pins on the PCM.
The check engine light was always on with the stock PCM, due to a dead MAF sensor. Heath set me up with an F program, so I have the MAF disconnected. Since installing, the check engine light has not come on, other than at startup to show that the bulb is good.
I recently picked up an Autel MaxiTrip TP100 from Princess Auto. It seems to work well. It shows me quite a few parameters while the engine is running and will check DTC's. It tells me there are no codes. Typically, I have used a SnapOn scanner or TechII for checking codes, but my mechanic friend has been hard to meet up with.
I can think of a few things that could be causing the cruise control to not work:
1) Bad PCM - when I installed the Heath GL4, I assume this ruled out the possibility, because its unlikely two of them would be bad.
2) Bad wiring in cruise circuit - voltage at the PCM suggests this is not the case
3) Bad PMD - I am not getting any codes. The only times the truck has ever stalled were due to bad lift pump shortly after purchase and due to bad EDAM cable. All of these events were prior to cruise control quitting.
4) Bad brake switch - Again, I am not getting any codes, my brake lights work, and when I tap the brakes while moving, the idle speed decreases. This tells me that the PCM is seeing the brake switch signal as it should.
5) Bad APP - No codes. Never had any issues that would suggest this is the problem.
6) Bad PMD cable - The only thing that really changed between 100% cruise operation and cruise control failure was the cable, and with the other one being so poor, I have been hesitant to swap it back in for testing.
So, now that I have prepared a novel on the subject, I'm going to call on you guys to help me diagnose this. I am going to scan with the TechII as soon as I can to see if there are any codes that the Autel scanner will not read. The only other things that I can think to try now are switching the old PMD cable back in, and getting a good known PMD to try.
Am I missing anything? :mad2:
Thanks in advance!!!
