chevyinlinesix
Eyre Flow Headers
Okay, well I went over to the shop to take a picture... and forgot I bolted the backing plate back on the water pump :mad2: So I'll explain it.
Behind the water pump impeller there is basically a donut of open space that the coolant is drawn in through. Different diameters of that opening dictate the surface area of fins on the impeller exposed to the inlet. They range from 75mm to 92mm IIRC. What has to be done it the impeller removed from the pump, and the donut opening (inlet) widened to 114mm IIRC. You can go a bit bigger with this size, and they also radius the edges of the donut so that cavitation is less of a problem. There is also a notch cut in the side of the impeller, but I forget how of if they modified it. I believe the HO pumps had the notch, while the lower flow ones you have to cut the notch out.
To help equalize the flow from bank to bank out of the water pump, there are "points" that are part of the outer casting of the water pump. Altering the shape of these points "scrapes" more or less coolant off the fins from one side to the other. I don't know how to shape the points without some trail and error work. It's pretty easy to measure the flow as it is just measured in gallons/hour or gallons/minute.
I was concerned originally about putting work into a part that wears out, but they do last pretty long, and with no fan the load on it is less.
